Thread Rating: 0 votes, 0.00 average. Rate: - Thread Rating: 0 votes, 0.00 average. Rate:
The Devil Z appears in Turbo Mag, Or something similar hehe
| Midnight Star |
That car is beautiful. Can someone post the wallpapers up here?
| Forrest |
| QUOTE (SilentNight1647 @ Jun 11 2007, 04:06 AM) | | I run a P90 head ported, stainless valves, ported, and bronze guides. The longblock is a N42 block, KA24 forged dome pistons, Nismo rods, LD28 crank, whole assembly is balanced. Intake side is a '77 EFI manifold extrude honed and a Q45 throttle body, exhaust is a turbo manifold also extrude honed. Turbo is .57 T3/T4 and a front mount off an Isuzu NQR truck. Runs about 10.5 to 1 with about 5psi. I dynoed it a while back at 447@7800 but its still a gutless wonder with only about 340ft/lbs of torque. |
Hey, are you on hybridz?
First, have you seen Tim's latest dyno? 607hp on his stroked L28/N42 combo, on pump gas (no nitrous or methanol.)
I think the biggest limitation you're going to have is the stock intake manifold if you're trying to push past your current setup (which I would probably be completely happy with.) I'm using one of Thaggard's aluminum intakes but I'll probably switch to ITB's soon. That seems to be what all the 500+ hp L6 guys are using.
The other thing is that compression ratio - I'm sure with 10.5:1 you don't have any complaints about lag, but can you run pump gas with that? My friend's 10:1 ported N42 setup would ping unless he was running 98 octane...
