QUOTE (Tchan @ Today at 5:28 AM) | I agree too.
If its a boost-on battle then your true skillz won't emerge, knowing that you will always catch up one way or the other.
Well for beginners that don't know whats going on, I leave the boost-on so they can have a slight chance |
i disagree
in a boost off battle, it isnt necessarily who's the better racer, but instead who gets in front first, at that point as long as the leader is semi good, they'll end up blocking the lines of the person behind them...not to mention the person behind has a harder time seeing(especially in 1st person), so this becomes in issue if say you start on c1 ib(just before the tunnel, like the old c1ib) against some other guy, you're on the left, hes on the right...guess who's gonna end up ahead at the first turn? its more often than not gonna be the guy on the right, and if the two guys are similar in skill, its likely the guy on the right will win
in a boost on battle, you can at least have fun(yes, ramming is fun, you should try it) although it makes more sense if there are 4 machines
if you want a test of TA skill, heres what you do.......TIME ATTACK
