7 Pages  1 2 3 » ( Go to first unread post ) Reply to this topicStart new topicStart Poll
> LEFT Foot braking?, Let's see if you're quick at switching
Do you use your left foot for brakes?
YES [ 150 ]  [60.98%]
NO [ 73 ]  [29.67%]
HEEL&TOE(4REAL) [ 23 ]  [9.35%]
Total Votes: 246
Guests cannot vote
KINO
Posted on Oct 22 2007, 07:45 PM
Are you the Kai Kogashiwa type (Initial D flying blue MR2 guy)
or the normal but quick at switching from gas to brake & V/V?
hanzel2m
Posted on Oct 22 2007, 07:55 PM
oh yeah I got a question,
I don't use the brakes to be honest, coz my friends told me not to lol
but do you really need to use the brakes? coz I just adjust the speed using the gears, so which one is better? using the gear or brakes?
z1t0
Posted on Oct 22 2007, 10:01 PM
i only use breaks on a couple of turns on HANSHIN
MaxX
Posted on Oct 22 2007, 10:32 PM
QUOTE (z1t0 @ Today at 10:01 PM)
Two red turns on Hanshin require the brake unless you walltap, and even then...
There's one red turn though that you should come out of at around 270 without letting off the gas or braking.
I use my left foot to brake in MT3, irl I use my right foot.
Dark Magician Ka..
Posted on Oct 22 2007, 10:54 PM
I am one who uses left foot braking. I have been used it it for quite a while.
I brake on the corners as necessary, especially on a few C1 and Hanshin corners. As long as I don't hit the walls and/or it makes my TA time lower, I'll be satisfied and happy of the fact that I used the brakes.
This post has been edited by Dark Magician Kamiya on Oct 22 2007, 10:55 PM
Mooo
Posted on Oct 22 2007, 11:41 PM
I dun use brake on hanshin.
But i believe it would be faster if i use brake as many people are using brake on the 2 red turns.
Will try it someday B)
FClover
Posted on Oct 22 2007, 11:50 PM
All hail the Gurren Brigade!
Kay...it might be just me being noobish...
But i do brake alot...not like holding the brakes when going into a corner...
More like tapping on them...especially in Hakone... :unsure:
KINO
Posted on Oct 23 2007, 12:15 AM
IRL, I use my right foot.
in Arcade, I also use my right foot.
kelvio
Posted on Oct 23 2007, 12:42 AM
left foot for me,
fight foot i can play throttle right foot tap the brakes get more slide
Posted on Oct 23 2007, 01:29 AM
Real Life: Right foot plus Heel/Toe when racing...
Arcades: Left foot or Heel/Toe depending on the course...
BDDEE@
Posted on Oct 23 2007, 02:48 AM
i just use my left foot, theres really no purpose using heel/toe on a arcade game since it does nothing
bekk
Posted on Oct 23 2007, 04:02 AM
i almost never use brakes, quick-switch if i have to.
evo_Sieg
Posted on Oct 23 2007, 04:20 AM
Location: Quezon City, Philippines/North Luzon Expressway :D
I left foot because if I don't, then my left foot is useless! It'll cramp up!
If there was a clutch (like Battle Gear 4) perhaps I would be right-foot braking. As it is its more practical to do so. It also frees up my right foot to dance with the throttle. :D
Posted on Oct 23 2007, 04:31 AM
QUOTE (evo_Sieg @ Today at 4:20 AM)
I dont use i it kuz im lazy!, but wat evo said in BG4, I use my left 4 clutch ;D
Posted on Oct 23 2007, 04:58 AM
2.5L Boxer 4
Currently still learning to LFB...
Only LFB in hanshin... that's it... :P
Still a noob in WMMT... :*(
BeastinLondon
Posted on Oct 23 2007, 04:59 AM
Beast of the Highway
i use my right foot for braking, that's if i brake (it happens sometimes). and here's my noob question: what's heel toe?
Tchan
Posted on Oct 23 2007, 06:42 AM
LegendaryMunky
Yes in the game.
Posted on Oct 23 2007, 07:51 AM
QUOTE (BDDEE@ @ Today at 2:48 AM)
It'll still create a smoother transition for your car during cornering but only from braking into accelerating. It does nothing for your shifting.
From track experience I do both left foot and heel toe depending on which is more convenient or comfortable for me. Typically when one is racing in the same gear or has a non clutch transmission. Almost all real race drivers will tell you that left foot braking is superior to having to do some form of heel toe. Look at F1 drivers. All the best of them use left foot braking during a race and almost never use the right to brake.
FClover
Posted on Oct 23 2007, 08:12 AM
QUOTE (BeastinLondon @ Today at 4:59 AM)
Heel-toe is when you use your right foot to control both the gas and the brakes at the same time...heel on the gas...toes on the brakes...hence the name heel-toe...
If done correctly it usually results in smooth down-shifting and are usually applied during corner entry...
That's about what i know about heel-toe...: \
Feel free to add anything or correct any mistakes on my part...
Sailor Enlil
Posted on Oct 23 2007, 08:30 AM
The Wangan Jedi
Yes I use left-foot braking. Most professional race drivers, particularly if the car has no clutch pedal (eg semi-automatic or for example the behind-the-steering-wheel paddle shifters like those used in F1 cars) do so. It's the best way to induce oversteer by "playing" with the brakes and gas.
ImmortalDrifter
Posted on Oct 23 2007, 09:16 AM
WME Inactive Godly User
I rarely use the brake. My "Difference in the way you brake" thread changed that. People said that they didn't use the brake a whole lot, so I've stopped doing it.
If you read the last part of my post from that link above about my plan on sending a video, well... I didn't video record it... so I'll show you two WMMT2 Story battles that I put on YouTube:
Reina vs. Tatsuya Race 1
Reina vs. Tatsuya Race 2
Two failed races.
This post has been edited by maxidrifter001 on Oct 23 2007, 09:21 AM
terencemk
Posted on Oct 23 2007, 06:48 PM
QUOTE (FClover @ Today at 8:12 AM)
ur correct :P
just to add on (real life) , with clutch control and heel toe technique,
you can make your car perform a well controlled drift. ( Of course!! definately not on a commercial car or you'll end up crashing / flipping ). And don't forget the stress your tires and engine have to endure. :P
This post has been edited by terencemk on Oct 23 2007, 06:50 PM
Fredrick2003
Posted on Oct 23 2007, 06:58 PM
Wangan's Fastest HiAce
Nah, right foot for everything, while my left foot rests comfortably.
This post has been edited by Fredrick2003 on Oct 23 2007, 06:59 PM
Posted on Oct 23 2007, 07:55 PM
left foot for braking helps decreases the time between letting go of the gas and braking.
that's why many players use left foot braking in arcade games.
ImmortalDrifter
Posted on Oct 24 2007, 09:14 AM
Right-foot braking= Noob
Left-foot braking= Semi-Pro
No-braking-just-letting-off-the-gas= Semi-Noob
No-braking-just-downshifting-and-drift= Pro
Hitting-the-wall-when-that-happens= Noob
Wall bounce technique= Semi-Pro
This post has been edited by maxidrifter001 on Oct 24 2007, 09:16 AM
Topic Options 7 Pages  1 2 3 » Reply to this topic Fast ReplyStart new topicStart Poll
